Unable to configure Tarot Peeper T10x
After I have installed Tarot camera I encountered several control configuration issues.
First one, it is impossible to deactivate gimbal stabilization
Second one, when I activate zoom it also rotates camera
It seems that several actions are assigned to same control (AUX)
Third one, I dont know how to configure Tilt and Pan.
Is this related to CubePilot hardware at all? I suggest you wait for answers over at the Ardupilot forum.
From the symptoms, this sounds more like a channel/function mapping conflict than a hardware failure.
Especially:
  • zoom triggering camera rotation,
  • and stabilization behavior not disabling correctly.
It feels like multiple functions may currently be sharing the same AUX/control assignment somewhere between HereLink, ArduPilot, and the gimbal controller itself.
A few things I would check systematically:
• Verify that zoom, tilt, and pan are each assigned to completely separate RC/AUX channels
• Check for overlapping RCx_OPTION assignments in ArduPilot
• Verify the gimbal control mode/protocol being used (PWM vs MAVLink vs serial)
• Check whether stabilization is being enforced internally by the Tarot gimbal itself rather than by ArduPilot
• Confirm that HereLink wheel/switch mappings are not duplicated unintentionally
• Temporarily disable all non-essential AUX mappings and test one function at a time
The “zoom also rotates camera” behavior especially feels like either:
  • shared channel mapping,
  • overlapping PWM ranges,
  • or mixed control assignments inside the gimbal configuration.
I would probably isolate the system step-by-step:
  1. Get tilt working alone
  2. Then pan
  3. Then zoom
  4. Then stabilization modes
before combining all functions together.
Dr. Fares Al Dhaheri
Al-Etihad Industrials, UAE
