Vibration Isolation Specifications and Certification for Flight Control Module
Dear CubePilot Team,
I hope this message finds you well.
We are Killis Bird LLP, a two-year-old startup specializing in drone manufacturing for a variety of applications through the assembly of drone parts and accessories. Recently, we procured your Flight Control Module for use in one of our key projects, which is expected to operate in environments with varying levels of vibration.
We noticed from both the documentation and the physical design that a vibration isolator has been implemented in the IMU section of the module. Given the nature of our application, it is critical for us to assess the vibration handling capabilities of the module.
We would greatly appreciate it if you could provide the following information:
  1. The range and types of vibrations your mechanical isolator is designed to mitigate.
  2. Details on any testing or certification carried out to validate the effectiveness of the vibration isolation system.
  3. If available, any test reports, certification documents, or technical data supporting these claims, as we require them as part of our type certification process.
Thank you for your support. We look forward to your response.
