Topic down for maintenance… Julien is working on it…
@RoboMotic,
Hi, Can you please guide how did you get the video out of herelink to QGC on ur tablet/IOS. What are the configuration settings that you made on herelink or tablet/IOS. After several tries, i have not been able to get video signal; only telemetry data is being received…
Regards
Yasir
hi!
Here are the instructions
https://docs.cubepilot.org/user-guides/herelink/share-video-stream
Bye!
@RoboMotic,
I am asking about the video streaming directly in QGC or Mission Planner and not on VLC Player… I have observed a great deal of latency in VLC player.
…is the same…
You have to go to the QGC on your tablet and find the video options, select the RTSP protocol and put the same address…
Works like a sharm
@RoboMotic
Hi, I have just checked all my settings… In the herelink, i have the following settings…
While in tablet, i have following configuration:
The end result is:
Can you please guide regarding this issue:
Regards
Yasir
your wrote: 192.168.43.1.1
The right one is 192.168.43.1
@RoboMotic, i made the correction and it is working fine with the apple tablet… Thaaaaanks for the help… I shall check with the laptop as well and will share the results…
Regards
Yasir
If you put the correct protocol and conection info you will be fine.
Bye!
@RoboMotic, Hi and how are you? The video and telemetry data is working fine on laptop via UDP Connection through GGroundControl. I want to ask further that whether the udp connection works for video diaply on mission planner as well? Actually i was able to recieve the telemetry data but could not recieve video streaming in mission planner. Can u plz help/elaborate in this regard?
Thankyou
Yasir Khizar
Hi
I haven’t try the video with MP from HL.
When I turn on the HL and MP I will try it and let you know.
bye
@RoboMotic, Did u try the video in MP? If yes, please tell the details how can it be configured.
Thanks in advance
Regards
Yasir Khizar
hi,
i’m trying to get the video on VLC media but i get this message :
live555 error: Failed to connect with rtsp://192.168.43.1:8554/fpv_stream
main error: connection failed: Connection refused by peer
satip error: Failed to connect to RTSP server 192.168.43.1:8554
what is wrong ?
Thanks.
Pascal
Did you followed step by step this tuto ?
Best,
hi,
yes i did!
do i need to be connected to the air module to make it work ?
another question for the tethering : is the usb c type Thunderbolt 3 ?
You must power the air unit to get it working.
yes ! thanks. the video
with VLC : lantency +/- 2 sec
with qground : latency +/- 0.4 sec
i think that it is flyable !
hi,
First flight with the hotspot on and Qgroundcontrol on my phone.
the video quality isn’t very good on youtube , better on the phone.
the main problem isn’t the latency but the video “jerked”.
hi,
what is the quality of the video out of the stream ?
Not super bad but it kills a bit of the quality and add a lot of latency.
The best way if you want the video feedback on a larger screen is to use an USB to HDMI converter like the U-Green one, it duplicate the video without latency and without quality loss.
Best,
Julien
