It is possible to share the video on the Herelink ground module using “Video Share” option. It has a bit of a latency though, on my system, around 2-3 seconds of latency. Any way to improve that?
@Julien Thank you for that solution! The problem is that i have to have a vlc player installed in some computer.
@philip I believe there is a better way to do screen mirroring, if you want i can help…
The best way to do it would be to enable the CAST option on android and literally mirror the whole screen to the TV/Chromecast… I think to do this we would have to go to the home menu and probably install another app. I offer my help to see which way is possible to do this, i would just need a way to go into the home screen.
Let me know if I can be of help or if you find a way to mirror the screen.
@sidbh Is there anyway i can do this to be able to cast the screen? I tried it from the cast menu in settings, but no devices appear there I think I could get it to work with an external app if i can get access to the home screen.
I was trying to do this too, and on my tablet I Put the video streaming configuration on the video Source from the General Options on QGround Control, and now I have all the data replicated, on my tablet I have the video an all the telemetry and drone control. BUT, you only can see the camera the remote is looking at.
If its a different way or its posible to see booth signals at the same time will be great
I’m curious with Robomotic as to if it were at all possible to be able to see both HDMI ports simultaneously. The transmitter unit seemingly has enough bandwidth to do so. Why is there up to 20 second delay to switch between the two?
I need to be able to remote pilot the drone through one FPV(hdmi) camera and use the other port for gimbal mounted operations.
Hi
Is it possible to broadcast the Mavlink serial signal to another device eg a PC running Mission planner. Does the herelink have a Bluetooth module if so do you plan on using this with SPP protocol to broadcast to another device. If this is possible I could use the transmitter for video feed and not connect to QC ( mavlink to other device ) I assume I will still have RC control.
Do you mean in the future we will be able to get simultaneously both video stream directly in the ground receiver? If yes, when is it planned to be released?
