Seem to have issues getting a consistent connection to hdmi feeds.
Is there a known connection procedure? Should the video stream (camera) be powered up before powering the air unit? Should the air unit be powered up then power on the cameras? Should you disconnect and reconnect the hdmi at the camera end after air unit powered up?
Seems if I fire up the air unit 10 times - 3 times I get feed, 3 times I have to power on/off the cameras and or air unit and 4 times it never provides a feed.
Also, what does ā1080pā slider do? Seems the quality is unaffected whether that is enabled or not.
@philip
