I want to use two ( 6s 6200mah ) batteries with parallel connection giving me the output as 6s 12400.
How can I get the battery voltage and mah capacity readings in solex tx app in herelink ?
Any suggestions ?
Dual power module? Probably from Mauch Electronic?
Will it show individual battery pack voltage ?
In solex tx herelink ?
I have never use this product before, but probably not. As you can see the connection, it combines the battery senses into 1 and feeding to POWER1 only.
I haven’t used it before but I’m a user of one of the power modules. I have used a lot of different power modules but the Mauch one is still the best I have ever seen.
If I read the description of the hub I think it is a good solution for some scenarios. Otherwise you can still use both power ports and monitor the batteries on you’re own, can’t you?
