k-kleber
(Kevin Kleber)
12 September 2022 17:59
1
Hello Everyone,
After a lot of trial and error I finally managed to build the herelink qgc version.
I do however get some errors and wanted to check if they are normal or need to be solved.
I want to be able to reproduce the default apk before starting any customization.
Thanks for any guidance.
Here the compile output:
gistfile1.txt
23:16:42: Running steps for project qgroundcontrol...
23:16:42: Configuration unchanged, skipping qmake step.
23:16:42: Starting: "/home/herelink/QT/android-ndk-r20-linux-x86_64/android-ndk-r20/prebuilt/linux-x86_64/bin/make" -j6
make: Nothing to be done for `first'.
23:16:43: The process "/home/herelink/QT/android-ndk-r20-linux-x86_64/android-ndk-r20/prebuilt/linux-x86_64/bin/make" exited normally.
23:16:43: Removing directory /home/herelink/build-qgroundcontrol-Android_for_armeabi_v7a_Clang_Qt_5_12_6_for_Android_ARMv7-Release/android-build/assets
23:16:43: Removing directory /home/herelink/build-qgroundcontrol-Android_for_armeabi_v7a_Clang_Qt_5_12_6_for_Android_ARMv7-Release/android-build/libs
23:16:44: Starting: "/home/herelink/QT/android-ndk-r20-linux-x86_64/android-ndk-r20/prebuilt/linux-x86_64/bin/make" INSTALL_ROOT=/home/herelink/build-qgroundcontrol-Android_for_armeabi_v7a_Clang_Qt_5_12_6_for_Android_ARMv7-Release/android-build install
/home/herelink/Qt5.12.6/5.12.6/android_armv7/bin/qmake -install qinstall -exe release/libQGroundControl.so /home/herelink/build-qgroundcontrol-Android_for_armeabi_v7a_Clang_Qt_5_12_6_for_Android_ARMv7-Release/android-build/libs/armeabi-v7a/libQGroundControl.so
23:16:47: The process "/home/herelink/QT/android-ndk-r20-linux-x86_64/android-ndk-r20/prebuilt/linux-x86_64/bin/make" exited normally.
This file has been truncated. show original
