Hello.
I am using Cube Orange plus, but I am troubled by the beeping phenomenon from the ESC.
I’ve tried reinstalling the firmware, calibrating the ESC, and checking the PWM values, but the issue remains unresolved. Is there anyone who knows if the Cube Orange Plus is compatible with HOBBYWING XROTOR 40A ESC or DJI E305 430 Lite ESC? What ESC are you using with the Cube Orange Plus?
@inquire_Roppor what is the signal requirement for the ESCs you are using? make sure you correctly set BRD_PWM_VOLT_SEL Complete Parameter List — Copter documentation
