The data type ID in the node ID may be wrong, but it is because of the error that successfully avoided the conflict with the correct data type ID
#define CAN_ID2_OUT ((u32)0x1109216)
//Pack the payload to be sent
void CAN_CustomerCode_TX(void)
static uint32_t tickstart_CAN = 0;
static uint32_t ticksotp_CAN = 0;
if(tickstart_CAN == 0)
tickstart_CAN = HAL_GetTick();
ticksotp_CAN = HAL_GetTick();
if(ticksotp_CAN<tickstart_CAN)//
ticksotp_CAN=0xffffffff-tickstart_CAN+ticksotp_CAN;
else
ticksotp_CAN=ticksotp_CAN-tickstart_CAN;
if((ticksotp_CAN>250)&&(CAN_TX_Falg == 0))
tickstart_CAN = 0;
ticksotp_CAN = 0;
else
return;
//Battery manufacturer code
CAN_CustomerCode.gBatCode[0]= BMS_config.CustomerCode.gBatCode[0];
CAN_CustomerCode.gBatCode[1]= BMS_config.CustomerCode.gBatCode[1];
//Battery model code
CAN_CustomerCode.gBatCodeNumber[0]=BMS_config.CustomerCode.gBatPack[0];
CAN_CustomerCode.gBatCodeNumber[1]=BMS_config.CustomerCode.gBatPack[1];
//Total voltage 1mV
CAN_CustomerCode.gVoltSum = BMS_config.BMS_Read.gVoltSum*100;
//Current current value
CAN_CustomerCode.gCurrent = BMS_config.BMS_Read.gCurrent*10;
//Average temperature
CAN_CustomerCode.gTemAvg = BMS_config.BMS_Read.gTemAvg;
//Battery pack SOC
CAN_CustomerCode.gSOC = BMS_config.Pack_RW_config.gSOC;
//Number of cycles
CAN_CustomerCode.gsCycleCnt= BMS_config.Pack_RW_config.gsCycleCnt;
//Battery pack SOH
CAN_CustomerCode.gSOH= BMS_config.Pack_RW_config.gSOH;
memcpy(&CAN_CustomerCode.g_Volt_call,&BMSVoltTemperature.g_Volt_call,
sizeof(CAN_CustomerCode.g_Volt_call));
//Design capacity of battery pack
CAN_CustomerCode.gSetPackCapacity = BMS_config.Pack_RW_config.gSetPackCapacity*10;
//Remaining capacity
CAN_CustomerCode.gSurpulsPackCapacity = BMS_config.Pack_RW_config.gSurpulsPackCapacity*10;
////////////Need to fill in the real fault code////////////////
CAN_CustomerCode.gAlarm[0] = (gBitChgLowTemAlm|gBitChgLowTemAlmPrt|gBitDchgLowTemAlm | gBitDchgLowTemAlmPrt)|\
((gBitChgHighTemAlm | gBitChgHighTemAlmPrt|gBitDchgHighTemAlm | gBitDchgHighTemAlmPrt)<<1) |\
((gBitChgOverCurrentAlm|gBitChgOverCurrentAlmPrt<<2)) |\
((gBitDchgOverCurrentAlm|gBitDchgOverCurrentAlmPrt)<<3) |\
((gBitVoltDiff1MaxAlm) | (gBitVoltDiff1MaxAlmPrt) | (gBitVoltDiff2MaxAlm) |(gBitVoltDiff2MaxAlmPrt)<<6) |\
((gBitOverVoltAlm | gBitOverVoltAlmPrt)<<7) |\
((gBitUnderVoltAlm | gBitUnderVoltAlmPrt)<<8) |\
(gBitChgShortCircuit<<9) | (gBitDchgShortCircuit<<10) | (gBitSOClow<<11) |(gBit_Chg_Error<<12);
CAN_CustomerCode.gAlarm[1] = 0;
memcpy(&CAN_CustomerCode.gXUHAO,&BMS_config.CustomerCode.gBatCodeNumber,
sizeof(CAN_CustomerCode.gXUHAO));
CCITT_CRC16Init((u8 *)(&CAN_CustomerCode.gBatCode),(sizeof(CAN_CustomerCode)-2));
CAN_CustomerCode.CRC16 = CCITT_CRC16;
//Put the payload to be sent into the sending array
memcpy(CAN_Tx_payload,&CAN_CustomerCode,sizeof(CAN_CustomerCode));
CAN_T_LEN_SUM = sizeof(CAN_CustomerCode);
gCAN_flag = 1;
CAN_Tx_Flag = 1;
CAN_Node_Id =CAN_ID2_OUT; //Load the 29-bit ID of the data packet
//250ms send a complete frame once, 1ms send a packet (<=8byte)
u8 CAN_TX_BcmuMsgHandle(void)
static CanTxMsg TxMessage;
static u8 can_pack = 0;
static u8 can_send_cnt = 0;
u8 temp_i = 0;
if(CAN_T_LEN_SUM < 240)
if(CAN_Tx_Flag == 1)
for(temp_i = 0;temp_i < 7;)
TxMessage.Data[temp_i] = CAN_T[can_send_cnt++];
temp_i++;
if(can_send_cnt >= CAN_T_LEN_SUM)//发送到了最后一个 字节
break;
TxMessage.Data[temp_i] = 0x40 | can_pack | ((can_pack%2) << 5);
else
TxMessage.Data[temp_i] = can_pack|((can_pack%2) << 5);
if(can_pack == 0) ///第一包数据处理
TxMessage.Data[temp_i] = 0xc0;//装载尾字节
else
TxMessage.Data[temp_i] = 0x80;//装载尾字节
TxMessage.DLC = temp_i+1;
TxMessage.IDE = CAN_ID_EXT;
TxMessage.ExtId = CAN_Node_Id;
CAN_Transmit(CAN, &TxMessage);
can_pack++;
if(can_send_cnt >= CAN_T_LEN_SUM) //Data transmission complete flag
can_pack = 0;
can_send_cnt = 0;
CAN_T_LEN_SUM = 0;
CAN_Tx_Flag = 0;
/*If the UAVCAN transmission is over, clear the UAVCAN transmission setting*/
if(gCAN_flag)
gCAN_flag = 0;
return 1;
//Check function
void CCITT_CRC16Init(uint8_t const * bytes, uint16_t len)
uint16_t j;
uint8_t i=0;
CCITT_CRC16 =CRC_CCITT_INIT;
while (len–)
CCITT_CRC16 ^= ((uint16_t)bytes[i++] << 8);
for (j = 0; j < 8; j++)
CCITT_CRC16=(CCITT_CRC16 & 0x8000U)?((CCITT_CRC16 << 1) ^ CRC_CCITT_POLY):(CCITT_CRC16 << 1);
