I was reminded today that Serial5 is assigned to the ADSB radio on the ADSB carrier board.
It appears that on a standard carrier board, Serial5 is available by using the SBus-Out and CONS ports.
Can someone please confirm that?
Looking at the other carrier boards, (mini, Airbot, Kore) there aren’t any connectors identified as either SBus-Out nor Serial5.
Does this mean that the only access to Serial5 is by using the non-ADSB standard carrier board?
