hi i am thinking about buying a herelink and i would like to know how to calibrate the ESC"s for my new build on the herelink…! thank you for your help.!
Ensure the HereLink is left powered on for the reboot of the ESCs
dear philip thanks for the help and is there any videos of this on youtube or any docs other then on arudopilot .?
The ardupilot docs are accurate
thank you philip i guess i will buy one and see how it go’s.
Most ESC are pre calibrated with known defaults these days. No reason you can not calibrate via the RC will a SBUS converter or via Ardupilot direct however you are far better using a servo tester now or even programming the ESC manually if you can. Remember the output of Ardupilot is full configurable so it’s less a case of calibrating the RC to the ESC and more deciding what rage you want to configuring that’s.
