Cannot increase GPS rate above 5hz on Here4
Hello all, I’m trying to increase the rate on my Here4 units for RTK use. They run at 5hz now but should be able to go higher according to U-blox documentation. Using U-center I configured the Here4 to use GPS and GLONASS constellations, this should allow 15hz for RTK. I can configure the rate to 10hz or 15hz in U-center and it acts like it saves and I can see it’s working. The problem is as soon as I disconnect and reconnect to check it, it goes back to 5hz every time. Any ideas?
Thank you,
Brad
Here4 has an option inherited from the ArduPilot stack, to auto-configure the GPS module at boot.
Look for GPS_AUTO_CONFIG in the DroneCAN parameters.
You can either disable this, and continue using u-center for the config, or you can set the GPS1_RATE_MS to 100mS, so the GPS will be configured to provide a navigation message at 10Hz
Use GPS1_GNSS_MODE to select just the required constellations, usually only two, and GPS_SAVE_CFG,2 to save to CAN units (along with serial units).
Then set GPS1_RATE_MS to the required rate.
Get a .bin log from the vehicle (or use MissionPlanner tuning panel) to check GPA.Delta to see if the desired update rate is achieved.
Thank you both, I’ll try to do the updated rate through mission planner!
I tried both techniques without success. Not matter what I do, I can only RTK at 5hz. Is anybody having success going higher with a Here4?
