H, my quad with cube orange and herelink boots on stabilize mode even that i dont have this mode configured. Anybody nows how to change that on any other mode that orange its cofigured?
Change the INITIAL_MODE parameter
Hi Alvin
Thanks but here is not such as parameter in copter 4.0.7
The best solution is a Lua script which runs (once) after startup and activates the desired flight mode.
@EosBandi has a nice example published here:
I think this is a new feature in copter and currently only available in copter’s beta.
So you either go for the beta, wait for the new firmware become stable, or use the lua script.
Thanks Alvin.
Do you have a set of procedure to add a lua script in orange cube
Check the Ardupilot docs for LUA scripting
https://ardupilot.org/copter/index.html
And also you can set
INITIAL_MODE
https://ardupilot.org/copter/docs/parameters.html#initial-mode-initial-flight-mode
hi
Unfortunately my bad luck that I am on a px4 stack with my Orange Cube for quite sometime…I am now thinking that i have to shift to Ardupilot sooner or later …thank you…
