Hi Everyone,
I’ve recently acquired myself a cube orange, and want to do some software development. The User Guide that came with my device references http://docs.cubepilot.org/Be_A_Developer which appears to be a dead link.
My intent is to use the blackmagic probe (or Zubax DroneCode Probe if that’s preferred) and serial wire debug interface to debug software on the FMU. But I can’t for the life of me find a reference diagram for the cube’s ADS-B carrier board. I’ve found references to the 80-pin interface (common across all cubes) containing IO and FMU SWD pins, but get lost when it connects to the carrier.
tl;dr: Where can I debug the Cube Orange (either directly, or through carrier / mini-carrier)? Where can I find more developer information for the cube?
Edit: I’ve pushed a PR to fix a lot of the formatting issues on that mentioned page. Am I correct in saying the correct approach to debugging the hardware is to purchase and solder a connector (SM06B-SURS-TF(LF)(SN)) to the (presumably) carrier board and attach to it that way?
Thanks for the reply - The only reference I can find of an inside of a carrier board (either standard or ADS-B) is from Bask Aerospace - standard carrier board. I hope what I’m understanding from @Sjourney is that the image of the underside of the carrier PCB is the two debug ports for IO and FMU. If that’s the case, I can place my digikey order and get started!
