Hi all,
I’m trying to install dual Here4 GNSS units on my Arducopter 4.5.6 Hexacopter. Each of the units work when plugged in individually, and enumerate to addresses 124 and 125.
When I plug them in together (tried CAN1 and CAN2 ports, and also both into CAN1 using splitter with same results) the LEDs on both units quickly flash white, then they go dead. They don’t enumerate in the DroneCAN explorer until one is unplugged and the system is power cycled.
What does this mean?
It was a power issue. The Cube Orange was not allow to supply enough power for two Here4’s and a Lightware SF/11. Powering one Here4 with a separate 5v supply solved the issue.
