ESC calibration joystick mapping
I am currently building an Autonomous boat. I have 2 motors and 2 servos. I am currently using a CubeOrange with the Herelink controller system and QGroundControl on the handheld controller. I am having trouble calibrating the esc and mapping the joystick. I want the right joystick in the center position to be zero so my motors do not spin up, but when I try to calibrate them they end up mapped in a weird position where I have to hold the joystick in a diagonal position so they don’t spin up.
I managed to get my servos for steering mapped perfectly with the servos set to ground steering and adjusting the PWM values. I have my two servos on Main Out pins 1 and 2
The motors are on main out pins 3 and 4. I have tried setting them to motor 1 and 2, throttle, but they seem to spin up the easiest using ground steering which doesn’t seem right.
Any suggestions?
Getting the sticks to cooperate can kind of be a bit of a struggle. I would do:
  1. Calibrate by the Herelink app first
  2. Calibrate by the GCS app
Give that a whirl and if it fails to work let me know, I was able to figure mine out and it was very troublesome.
Posts which may be of use:
Throttle stuck - #6 by stryngs << Really helpful for the order of operations.
