Thanks for the firmware.
I tested it on two cameras and when I select HDMI Force Output, the cameras crash, I have to re-load the firmware for it to work.
So for my part, it doesn’t work, I will continue to use a Firefly Q6 camera.
I just updated my firefly camera by flashing new firmware using SD card and connected the camera to a monitor, went into OSD, changed the video streaming or some resolution from 720p to 1080p 30 fps. After that just unplugged the cable to monitor and connected it to the firefly camera. It works fine.
I have two firefly cameras, both using the same principle.
Have had no luck with 4 firefly split 4K cameras. Tried various firmware etc. will show on a monitor but doesn’t register in any of my two herelink s.
Using most up to date herelink firmware, also tried beta firmware. Tried plugging it in and out again. Never once have I seen an image. Various cables etc.
Tried various firmwares. Ranging from those listed on here to others and the most recent ones too. Zero luck on 4 of them. They were brand new as of a couple
Months ago. Perhaps the new builds aren’t working now.
