Our Flir VUE PRO camera is not working with Herelink. I am using the camera with a video and power module adapter provided by Flir which outputs 1280 * 720P 60Hz video feed.
What HDMI formats is the Herelink system compatible with? Is there any way to configure the format?
@Abhishek
the flir video output is analog and you need an AV-HDMI converter to get a video from herelink … i did it and it work good ,but there is a problem which is the converter is big and heavy
Flir Vue pro is working with the new firmware as mentioned by you. Thankyou @philip and @Michael_Oborne.
My only concerns now are that I was about to ship out a new batch of drones with Herelinks, however, after changing this beta release on Air Unit, I’ll have to retest my system. Can you give me some idea on the stability of this new firmware? Also if you can mention the change log that I can test the features accordingly.
Yes. The FLIR VUE will work with a Composit to HDMI converter. You can by them on amazon for $20. I’m using the same setup and it works fine. Only drawback is the cabling and size of the box.
Please describe how you were able to get your Flir Vue Pro with the power and HDMI module installed working with HereLink. I have the exact same setup, but I’m not having any luck. I need for this to work. Thank you!
Hello, I have the latest firmware installed in my ground unit, and I have installed the above-mentioned firmware in the air unit ( the one @Michael_Oborne has put into the drive folder). Still, I am unable to get the stream on herelink.
Setup and Findings:
I have tested analog output on TV (indicating camera is fine)
I have tested it with HDMI converter ( comes along with Vue pro ) on TV (Indicating the digital conversion is fine).
I tried multiple things (plugging in HDMI 1 or 2, changing settings to 1080, 720p) but found no luck. Anyone, please help
Thanks @RoboMotic for the reply,
I am trying to get this done without the video converter
Because of the following reasons
This converter needs an extra power to run.
This converter adds more weight to the UAV
The converter is not shipped to India.
I have seen on the forums that the solution worked for people, without external analog to digital converters, so I am keen to know what I am doing wrong.
Also, I need to mention that, I tried beta firmware also, but no luck. I also tried switching analog outputs from NTSC to PAL from the flir app but not result. Is there anything I can try ?
Im struggling with this converter. Is there anything you can suggest to try? It works fine when using the flir hdmi converter but the one i got from Amazon isnt working. I have a tarot gimbal on the way and im thing maybe the bench flir cable might be the issue?
