Hello everyone. I have a problem with the HERE 3 GPS Module. When I connect to Mission Planner, I see a red-colored text (GPS: No GPS) and the GPS is flashing blue. What should I do? Can I reset or reboot the GPS Module? Note: When I tried with another HERE 3, I got GPS Location
Hi, have you solved the problem. I’m also having here3+ gnss. My problem is gps no fix. Will resetting the gnss solve this issue? If yes can you please help me in resetting
Thankyou
What is the LED status?
In stabilize mode, it is Flashing blue, after arming it went to solid blue.
In modes which requires gps like loiter, the yellow light flashing double times.
Check CAN inspector on mavlink-can tab of mission planner. Check if you have GPS data available there.
If he has GPS:No Fix, that means GPS is detected
Your issue is being tracked here Here3+ GPS No Fix Issue - Need Assistance - #9 by sidbh best not to hijack stale threads.
