Hello, I have here 2 and here 3 gps. I put them on custum box, and I want to put extra led diodes. The problem is that I don’t know what is the type of led diodes, and can’t find information about them. Do you can to tell me what is the diodes. Thank you.
I think it will be far more complicated than expected. The LED on HereGPS are program controlled in serial, which means you can’t simply add more.
The easier way would be profiLED with lua script
https://docs.cubepilot.org/user-guides/profiled/profiled#settings
Thank you. Do you know the type of led, because I can’t to find the same type in stores.
They are PC5XS301V0500.
You need profiLED if you want to go lua script way, because they are programmable.
