HERE 2 LED Colours
On the Here 2 should the LED Colours be the same as the original Here GPS
eg
Blue Flashing No GPS Fix and Disarmed
Blue Solid No GPS and Armed
Green Flashing 3D GPS and Disarmed
Green Solid 3D GPS and Armed
On the Here 2 GPS that I have its always bue even if Mission Planner shows a 3D Fix
David Ardis
Nothing has changed here is the link
http://ardupilot.org/copter/docs/common-leds-pixhawk.html
The short answer is yes, the LED behavior is defined by the autopilot unless you’ve changed the LED_MODE or LED_STROBE parameters on the GPS.
