Here 2 UAV CAN Safety Switch
To start with… let’s unpack my absolute hate of that switch.
First… calling it a safety switch… it’s not… is would be better to call it a finger removal tool!
Second… For it to be a safety button it would need to be monitored, checked and verifiable in functionality, it’s not, the design is a flawed concept.
Third… consider the use case… on a multicopter, props are stopped, arming is prevented by the “safety” switch, so to make it arm-able… you put your hand between the potentially spinning disks… and make it “unsafe”.
Forth… for some strange reason the button or wire gets damaged in flight… triggering the button… disabling the vehicle? In flight? Nuts!
I hate this button…
My advice to all is to set ardupilot to prevent this button from being able to be used while the aircraft is armed, and don’t use it at all.
ALWAYS ASSUME THE COPTER IS LIVE AND HAS IT IN FOR YOU!
