I’m trying to setup a here 3 to run on a Cube Orange+ with PX4
I’ve follow the instructions for PX4 here: https://docs.cubepilot.org/user-guides/here-3/here-3-manual#id-2.-using-px4-firmware. My setup is as follows:
FMU CAN1 - Motors are daisy chained and plugged in here
FMU CAN 2 - Here 3 plugged in here
UAVCAN Params:
-UAVCAN_Enable sensors and actuators (for the gps and motors)
-UAVCAN_SUB_GPS enabled
-UAVCAN_SUB_GPS_R enabled
UAVCAN Status:
-I can see the motors are operational
-Docs say that the GPS should automatically get id of 2, don’t see 2 as operational in the status
Pool allocator status:
Capacity hard/soft: 500/250 blocks
Reserved: 123 blocks
Allocated: 51 blocks
UAVCAN node status:
Internal failures: 0
Transfer errors: 0
RX transfers: 30274
TX transfers: 505984
CAN1 status:
HW errors: 62
IO errors: 62
RX frames: 38437
TX frames: 524747
CAN2 status:
HW errors: 510406
IO errors: 538897
RX frames: 0
TX frames: 496235
ESC outputs:
INFO [mixer_module] Param prefix: UAVCAN_EC
control latency: 753783 events, 197557455us elapsed, 262.09us avg, min 181us max 2478us 133.396us rms
Channel Configuration:
Channel 0: func: 101, value: 65535, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
Channel 1: func: 102, value: 65535, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
Channel 2: func: 103, value: 65535, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
Channel 3: func: 104, value: 65535, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
Channel 4: func: 0, value: 65535, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
Channel 5: func: 0, value: 65535, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
Channel 6: func: 0, value: 65535, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
Channel 7: func: 0, value: 65535, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
Sensor ‘gnss’:
Sensor ‘gnss_relative’:
Sensor ‘mag’:
Online nodes (Node ID, Health, Mode):
101 OK OPERAT
102 OK OPERAT
103 OK OPERAT
104 OK OPERAT
UAVCAN Param list 2
-Fails to grab param list for id 2
The docs are quite straightforward and I believe follow them, but the GPS doesn’t work and the LEDs, after flashing during boot up, are off.
What am I missing?
