Here 4 Blue Can1 Can2 wiring
I’m hoping I can get this answered soon before installing the Here4 Blue.
My issue is the color wires mentioned in the manual are Green, Blue, White, Grey. Is that the order they should be in starting with pin 1?
Pin1 = Green
Pin2 = Blue
Pin3 = White
Pin4 = Grey
I ask because the connector on the Here4 Blue I recently received is wired a little differently with pins 2 & 3 (blue, white) swapped.
Pin1 = Green
Pin2 = White
Pin3 = Blue
Pin4 = Grey
Or is it the Green and Gray wires are swapped?
Also, is my Can2 connector wired correctly, Pin2 = Orange, Pin3 = Brown
Ok! I guess I can open the Here4 Blue and figure it out with these images:
Does opening the Here4 Blue void any warranties? If it does, can someone from CubePilot or just someone who knows, provide an answer. PLEASE!!!
Check the image you attached of the plug, noting which side the clip is on. Your picture under it is in the same orientation (clip down).
1: 5V, Grey
2: CAN_H, Blue
3: CAN_L, White
4: GND, Green
This is what I’ve found:
Same as other sources
