Here+ Base (m8p) repurposed as a rover
Hello.
i Wish to know about the possibility of using the Cubepilot Here+ base module (m8p-2-12) in a different context.
As i have read , the m8p-2 can be used as a base and as a rover when reconfigured. Can i reconfigure the Here+ module in the U-center to use it as external gps rover with android device?
thnx for reading,
with regards,
Taavet M.
Estonia.
yes you can. so long as the android device detects it.
So if I had 2 Here+ base modules I could use one as the base station and the other in a drone as the rover and get rtk accurate data just like I would using the normal here+ combo?
yes, you just don’t get the mag.
