Hello everyone!
I purchased the here+ rtk gnss GPS kit for my project. My project doesn’t require to be worked with drones, uav. It’s manually operated so I was skipping the flight controller as I may not need it to work with rover. I was wondering if I can simply work with raspberry pi or Arduino kit.
However, while performing the setup, the manual asks to use pixhawk 2.1 flight controller to work with rover. Also, the cable with rover fits with the port in pixhawk flight controller, I couldn’t find it compatible with the raspberry pi or Arduino.
Can you please help me out how should I proceed? Does this here+ rtk gnss GPS work with other module as raspberry or Arduino, or it is only compatible with pixhawk flight controller? I would be very thankful to you for any suggestion/help.
