Hello @philip @sidbh,
I am using HERE3+ dual GPS with cube orange plus.
But getting warning messages- Prearm: GPS2 unhealthy…
Is there any solution. Please help me to solve this.
Thank you
Use them on different can ports… one on each
Thank you @philip Sir.
What about on mini carrier board for Two Here3+ GPS to use?
Mini carrier board has only one CAN port and both Here3+ shouldn’t not be connected on same port with different node ID?
I was tried with CUAV Neo2 Pro or Neo3 pro gps ( CAN protocol gps) on same port and it was working nicely.but why not with two Here3+ on one CAN Port?
It works with latest firmware.
FYI, reviving old threads doesn’t always show in my feed to review, this thread is marked solved, so I normally ignore solved threads
I will check it.
I don’t want to create new topic if you want have a new topic i don’t have any problem creating.
It’s not a problem, it’s just easy to miss
Today i have tried with AC 4.4.0 on Cube orange+ which is very latest firmware with Dual Here3+ on CAN 2 port of Mini carrier board with isolation Power to the Here3+. please refer the image below.
still have facing Prearm:GPS2 Not healthy.
here is the log for that :https://drive.google.com/file/d/1wLasTHZvMxbz9I2iqrtRH_yoBZYt7Sm7/view?usp=sharing
i have checked the GPA Delta parameter for each gps and found GPS2 Not maintaining 200ms update rate.
I have checked each gps individually and both of them working normally.
i have tested this both Here3+ on standard carrier board each GPS on each CAN ports.
in this setup its working normally and NO Prearm error as GPS2 not healthy.
problem is with mini carrier board only.
@sidbh @Michael_Oborne @tridge
Any ideas all?
