I own 3 x Here3+ GPS devices that I upgraded to Here4AP firmware. I was unable to upgrade one of the Here3+ using either Standard nor Beta version of Mission Planner. The reason I grabbed the Here4AP firmware is that I figured not seeing any Here3+ would have worked. May be this was a bad idea…
They were all responding successfully using the U-Center software. And also Mission Planner also reported successful operation…once. Until it didn’t anymore. I keep getting the “EKF3 waiting for GPS config data” message.
Now I’m not seeing any of them (one at a time) through the DroneCan/UAVCan menu option nor using the DroneCAN GUI Tool.
I’m able to connect with each Here3+ using the U-Center 24.02, however no firmware upgrade seems to work. What are your recommendations to revert back to the original firmware? Even if I want to use “Passing Serial over DroneCAN”, I’m unable to see any NodeID.
Below are pics of what I’ve done (lucky for me I got screenshots of all this).
Thank you for your help! My project is kind of running out of time, so I’d really appreciate your help.
Marty
