Another Here3 I own is working properly and U-Centre is reporting its firmware as HPG (it’s firmware was successfully updated using U-Centre and CAN passthrough as instructed in the manual)
I’ve tried updating firmware using multiple Pixhawk cube boards, as well as both legacy update and normal update mode.
Not sure where the issue is coming from. Would be glad to have a solution.
If it shows update success then its weird for the version information being not updated.
Restarting and reconnect u-center force it to reload the data it gets from chip. The u-center usually hold the previous loaded data in the field which may be confusing.
I think this is not what’s happening on you, but just to be sure.
After updating firmware, if I restart u-center it just doesn’t receive any data from the Here3. Even the packet console shows no messages from Here3.
However I managed to solve the issue. Not sure why but on setting the PassThrough parameter on MissionPlanner to 1 and then doing a firmware update resolved the issue. Now the UBX-MON-VER is showing EXT CORE and correct firmware.
