I am new to the CAN protocol. It looks like I will not be able to just connect this to GPIO pins on a Pi and send/receive UBX messages like I can with a UART GPS. I found this CAN bus controller for the Pi:
Am I on the right track? Has anyone used something like this with the Here3?
I am confused by your reply. The manual says the Here3 speaks over CAN not I2C. This post from last year:
says it might be possible to switch it to I2C via a hardware switch but the manual doesn’t mention that ability. I have found there is still no mention of that in the manual. Only of CAN connectivity.
Unfortunately my work requires I leave the firmware alone as I am testing the firmware of the device so modifying it could affect the results. If you mean that it is possible to switch to UART without modifying the firmware that might be an option, though changing settings would require that I could talk to it in the first place and I don’t have a cube to connect it to, just a PI.
