Hi!
One of our drones is showing a weird discrepancy between the number of satellites for each Here3 receiver (sometimes 8 satellites while the other gets 16!). We’ve been using a dual Here3 setup since 2020 and I don’t recall any similar episode.
Setup:
- Cube Orange+
- Kore Carrier Board
- Dual Here3 (simetrically placed)
Important Considerations:
- There are other drones, same model, that aren’t showing this issue
- We swapped CAN ports and the issue was still in the same receiver
- Antena interference is unlikely because of the simetric placement and lso because this issue is not happening in other drones.
- The difference sometimes gets smaller, but there is a difference almost all the time.
*Parameters are correct
*The receivers are in the same FW and version. - The “bad” GPS is indeed showing much worse GPA values, but the latitude and longitude reported through the flight, from both “bad” and “good” receivers, are perfectly matched.
Screenshots
**Link to LOGS"
https://drive.google.com/drive/folders/1FiAfmymgP33VA6Ahzo6ZShRFOAEZacTv
We’ll change the receiver, but in the meantime I’d like to dig deeper on this matter.
Questions
- What could cause such an obstruction?
- Could a small interference on the Here3 cable (the cable, not the receiver itself) cause that?
