Jai
(Jai)
31 January 2023 03:50
1
lately, I noticed that Here3+ either draws more ampere or causes a voltage drop that affected others peripherals connected to the carrier board.
test scenario:
Arducopter version 4.3.3 + CubeBlue H7 + Sik Radio v2.2 direct power, result okay
Arducopter version 4.3.3 + CubeBlue H7 + Sik Radio v2.2 direct power + HERE3+ result Sik Radio no power
Arducopter version 4.3.2 + CubeOrange + Sik Radio v2.2 direct power + HERE3+, result okay
Did anyone notice that?
Mike_ZY
(Mike_ZY)
2 February 2023 02:46
2
May I know which carrier board did you use and your set up?
Can you connect to mission planner and check the board voltage difference before and after connect with here3+ ?
Jai
(Jai)
2 February 2023 05:31
3
The default carrier board .
We have shifted to CubeOrange for now and use external power for Sik radio, and busy now. will update once I have the time.
Jai
(Jai)
3 February 2023 04:01
4
It could be due to telem 2 female port intermittent issue. Connecting to telem 1 female port, can’t reproduce.
Very appreciated for the response, patient and apologies for the false alarm.
