When I try to use the Here4 and Hereflow simultaneously, they stop functioning. However, they both work fine when used individually.
I have tried connecting them both via a splitter to CAN1, and also tried connecting them separately to CAN1 and CAN2. I also have a Here3+, which works fine when connected via a splitter to CAN1.
I suspect the issue might be due to either a power shortage or communication conflict. Could someone please help me understand the cause of this issue and suggest a solution?
It is highly unlikely that GPS modules are going to have such a severe impact on power budget. I would look into current draw by your motors, and see if that has changed between the logs.
