Here4 GPS NoFix problem
Hi
i just boat the HERE4 GPS with the new orange+ FC. i have done every thing like written in the setup manual. I go out with NoFix GPS…after 10 seconds i get the first stelite…4-7 second i loos it and i cannot get it again. i am getting message of unhealthy GPS signal/
all my other drone (dji) work perfect.
please advise
Asi
What was the height at which you were trying to get a 3d lock with your GPS signal
You mean the night from ground or high from the pixhwak level ?
Ground level… :slightly_smiling_face:
1.6m
That is the issue…raise it to atleast 25 meter high and check the GPS readings…
How can I get home point without GPS reading ? What if I am using it on Rover ?
@Asi_Bitton please share a log with GPS connected and clear view of the sky with LOG_DISARMED 1 and collect for 15mins.
Problem solved… broken gps cable (defective)
Change and it’s working perfect. Thanks to my local distributor Zohar.
