Here4 not connecting with Cube Blue H7
Using a Cube Blue H7 running V4.5.7 and a Here4 running HW 4.19 and SW 1.14.D42D3330.
I’m running into trouble with connecting the Here4 to the Cube Blue. I have followed the following tutorials to setup the proper parameters and connect through the CAN1 port on the Cube, but neither seem to get the two to connect:
Once the tutorials have been followed, it ends with the Here4 flashing double yellows, indicating that it’s connected. However, MP indicates ‘GPS: No GPS’. Within the setup pages, the Here4 appears within the DroneCAN/UAVCAN subpage, the HW ID subpage, and the Compass subpage (showing as an external compass).
We believe it is a firmware issue with the Here4, as a similar setup with a Here4 running HW 4.19 and SW 1.12.33C3E4E7 and a Cube Orange+ running V4.5.7 was setup with the tutorials above and is able to connect properly and obtain a fix. The firmware of the GPS was updated both through MP as well as through u-Center with firmware from the ublox website, both to no apparent improvement with the connection.
If any help could be provided, that would be great!
means there is no usable GPS signal.
Be aware of specific guidance about updating via U-Centre - you could lose moving-baseline functionality.
