Hey everyone,
I have a Here4 GPS and I tried to update the NEO F9P Firmware. I used the serial passthrough to connect to U-Center and everything seemed fine but once I started uploading the firmware it crashed and now it seems to be locked. Here is the log output from U-Center firmware update:
Setup pipes
Firmware update tool launched
-p STDIO -b 9600:9600:230400 --no-fis 1 -C 1 -s 0 -t 1 -v 1 "Z:\home\jacob\Downloads\UBX_F9_100_HPGL1L5_140_F9P.a953bd2d71061ed21cc6fdc431ab39a5.bin"
----------CMD line arguments-----------
Image file: Z:\home\jacob\Downloads\UBX_F9_100_HPGL1L5_140_F9P.a953bd2d71061ed21cc6fdc431ab39a5.bin
Flash: <compiled-in>
Fis: flash.xml
Port: STDIO
Baudrates: 9600/9600/230400
Safeboot: 0
Reset: 1
AutoBaud: 0
Verbose: 1
Erase all: 1
Erase only: 0
Training sequence: 1
Chip erase: 1
Merging FIS: 1
Update RAM: 0
Use USB alt: 0
0.0 u-blox Firmware Update Tool version 23.04
0.0 Updating Firmware 'Z:\home\jacob\Downloads\UBX_F9_100_HPGL1L5_140_F9P.a953bd2d71061ed21cc6fdc431ab39a5.bin' of receiver over 'STDIO'
0.0 - Opening and buffering image file
0.0 - Verifying image
0.0 - Got an encrypted image with footer info
0.0 - CRC Value : B8629764
0.0 - Footer Version : 0
0.0 - Number of Images : 2
0.0 - Footer Size : 28
0.0 - Image Config Size : 0
0.0 - Image 0 Size : 752372
0.0 - Image 1 Size : 539844
0.0 - Trying to open port STDIO
0.0 - Setting baudrate to 9600
0.2 - Sending training sequence
0.2 - Received Version information
0.2 - Receiver currently running SW 'ROM BOOT 1.02 (a11814)'
0.2 - Receiver HW '00190000', Generation 9.0
0.2 - Sending ROM CRC Poll
0.3 ROM CRC: 0x118B2060
0.3 u-blox9 ROM1.02 hardware detected (0x118B2060)
0.3 Getting Port connection to receiver
0.4 - Connected port is: UART1
0.4 Starting LDR TSK
0.4 - LDR TSK started successfully
0.4 Identify flash loader
0.5 - Uploader version 5.1 detected
0.5 Stop GPS operation
0.5 Detecting Flash manufacturer and device IDs
0.6 - Flash ManId: 0x009D DevId: 0x6015
0.6 - Not merging anything
0.6 - Flash size: 2097152
0.6 - Flash block: 512 x 4096
0.8 - Setting baudrate to 230400
2.0 - Retry poll
2.1 Chip erase started
2.1 Receiver info collected, downloading to flash...
Writing packet 1/2524
Writing packet 2/2524
Writing packet 3/2524
Writing packet 4/2524
Writing packet 5/2524
Writing packet 6/2524
Writing packet 7/2524
Writing packet 8/2524
Writing packet 9/2524
Writing packet 10/2524
Writing again packet 0
Writing again packet 1
Writing again packet 2
Writing again packet 3
Writing again packet 4
Writing again packet 5
Writing again packet 6
Writing again packet 7
Writing again packet 8
Writing again packet 9
227.2 ERROR: Write retries for packet 0 exceeded.
227.2 Firmware Update FAILED
Firmware Update Utility has unexpectedly terminated
Exit code (2)
The main issue now is that I cannot ever restore it to it’s previous settings.
Any ideas?
Thanks in advance.
