HERELINK - Compatible camera list
Both herelink remote have the same version:
Development herelink v4.0.8.dev:3d0bb7e
in one of them, the video dont works with the same av to hdmi adapter and a fpv cam, in the other, works ok
That is an old QGC version. The latest is V4.2.8
how is the proccess to install a current version of qgc on herelink?
The latest version is fully functional except it has only 1 x HDMI port working . I don’t understand why and who is messing around with the Herelink product. …lol…
With Herelink v1.1, GoPro Hero 3 White seem to work only in 720p. But sometimes it is a bit unstable. Sometimes it needs to reboot GoPro or Herelink in order to work.
Would be great if we had an explanation why it is working with some camera but not with others, HDMI protocol should be universal. That would simplify hardware selection and development.
Thanks.
Can anyone else confirm the same issues with herelink and Gopro Hero 3.
It shows as compatible on the list so I am planning to use this combo.
Thanks.
Cameras that are listed in this post have been reported working well by many users. We edited the list dozen of times to maintain it as close as possible to the reality.
But the list has been started since a while now (early Herelink v1) so some cameras can have had firmwares updates that can creates issues or unstability. I would suggest to test differents FW on the gopros if possible, this could solve this kind of problem.
GoPro Hero3+ working perfect out of the box
But this list is very old and I agree CubePilot should update this list for there customers.
Alas I am sure Cube pilot will never do such.
Has anyone tested Gopro Hero 11, 12 13 and new HERO?
I am using a Sony RX0 Mk I camera and have connected it to my Herelink 1.1 air unit via an HDMI cable. However, I am not getting any video output on the Herelink display.
I have checked the camera’s HDMI settings and ensured the cable is properly connected. According to the documentation, the Sony RX0 Mk I is compatible with Herelink 1.1, but I am unsure if there are specific configurations or additional steps required to make it work.
Could someone guide me on how to resolve this issue? Are there any particular settings I need to enable on the Sony RX0 Mk I or the Herelink air unit to ensure compatibility?
Any advice or troubleshooting tips would be greatly appreciated.
Thank you!
Thank you!
As you mentioned in your message it has been reported as working (out of the box). So it could be something related to a differences between the cameras FW versions in this case it would be hard to spot.
On other hand i would suggest to seach the camera menus to check if the output have to be activated (you can also connect it to any HDMI screen to verify if the output is already active)
Also check in the menus if you can change the output resolution, then test different ones if possible.
  • camera settings
This looks good, i wonder what is ‘CTRL for HDMI’
Does it display image when you connect to a monitor ?
Hello Airbot Systems. My name is Ken Flucas. I am a drone building hobbyist/enthusiast. I currently have a build on hold because I want a camera with zoom and night vision capabilities. I finally found 2 that are somewhat affordable for me but it is not on the current list of compatible cameras for the HereLink System. They are the TAROT T20X-3AB(with night vision)…&…TAROT T10X-PRO(without night vision but less than $400) Is it possible for someone at Airbot or HereLink or ANYONE to test these cameras with the HereLink System to see if they are compatible? Or are there some specific features that a camera/gimbal needs that I can look for to know if the camera/gimbal is compatible with the HereLink System? I also plan to use the Air Commander ENTIRE R3 with the Pixhawk Orange Cube. Thank you.
Hi Ken, sorry for the delay, but we are over busy these days.
So unfortunately we can buy cams just to test them. So if no one as reported it tested or simply published a picture, a posts or a youtube video that proove it works, someone has to jump in to verify…
Entire commander R3 is compatible, for sure
Siyi A2 can work but need a lot of modifications and a HDMI convverter.
