You won’t, but if you want to run custom antennae, connect at the u.fl at the pcb inside.
I was trying to understand these BNC connectors and all while reading all the answers. However, I am stuck with the removal of the antenna from the Ground unit. Once it is removed, then only we can go ahead with the extension
@philip thank you so much for your reply. I am sorry i didnt see the notification, in time. But all this time i am still trying to figure out what i can do.
I dont have much experience with the PCB desoldering and things like that. I was looking for a simple solution. I want to do the same as @pparm. did. (I took the image from his post in the top. )
I hope you could help us for this.
the antennas clip onto the pcb with u.FL connectors, no soldering needed.
That is really cool so i can use a u.FL to SMA adaptor that means.
Thank you so much @philip . If you an image of this please share it, it might be helpful before i open my controller.
Hi David. Looks like you’ve found a solution that I need too.
My AC antenna’s are mounted (both on same side) to a plastic tank (agri drone). When the tank is full and if the tank is on the opposite side of RC I sometimes get signal loss. I wan to extend the antenna cables so I can mount below the tank and have clear signal transmission.
I’m not certain which ones to use. Essentially I just want to extend about 400mm.
Any help appreciated
Hello Everyone,
So aside from desoldering the Herelink GCS to install more a standard SMA female connector, there are not off the shelf solutions that allow connection to an external antenna to the ground station, is there?
Thank you,
Marty
I am curious how this worked out for you. Good results?
No de-soldering needed. Pry the side handles off the controller, take the back off and you’ll see that if you find something like this ( Tenmory UFL to SMA Mini PCI U.FL to RP-SMA Female Ipex Connector Pigtail Antenna Extension Cable (6 inch (2 Pcs)) Amazon.com ) you can change out thebhard to find Mini BNC 50ohm connectors for RP SMA. Just keep in mind youll want a quality coaxial cable with 50 ohm resistance.
