Has anyone mounted their HereLink Ground Station antennas separately from the handset? For example, by using a cable to put the antenna on a tripod or mast?
Example motivations:
To separate antenna orientation and positioning from handset (e.g. antennas elevated on a mast)
Change to a different antennas (e.g. directional, higher gain, etc)
Downsides:
Ground Station design was optimized for OEM antennas.
I am curious about this setup as well, but add in a tracking motor base. When I’m running a long range autonomous mission (pushing the edge of my VLOS) it’s more than a bit annoying to aim the antenna where the aircraft is since this they are typically 30-40 minute missions.
It gets very hot in the sun where I fly missions so it would be nice to take refuge in a shade tent with the GCS and RC and not have to babysit the antenna. I am planning to expand missions to BVLOS (with FCC authorization) in the future with +60 minute missions and a tracking antenna on a mast would fit the requirement nicely along with the Herelink RC.
I’ve seen an external antenna with tracking setup with a 3DR Solo remote. Maybe it can be somewhat replicated. I think the main concern is that adding components can and typically do have a negative effect on signal, specifically the connections. I’ve learned this with GPS survey modules in practice, so the fewer the connections the better.
Interested to see if anyone has been trying anything yet.
I am about to go down this path too due to terrain and maximizing range during BVLOS operations.
The BNC connectors are some form of Mini BNC but of a specific type so good luck with finding some. The alternative is to open the back up, disconnect the U. FL connectors ( ipex v2 2 mm?) and replace them with a SMA end . You can also try to canibilise original antennas and make a adaptor to SMA and then extend using 50 Ohm coax to elevated antennas which is the way i’m going for want of the correct part number (keep getting something bigger than the Herelink connector but called “mini”)
