Herelink v0 support for ip camera with gimbal
Ethernet passthrough does work - given that you have compatible usb ethernet adapters and please note that on air unit you need to power it externally.
See these threads:
I have used Asix AX8817X based usb 2.0 ethernet adapters successfully - but there are also couple of other chipset versions supported I guess.
