its being prepared at the moment.
we plan a simple update, then a larger second update that adds new features
I’d like to try the simple update now if possible.
Finally got the GoPro7 connected via HDMI. When I press record on the GoPro, the feed to The controller cuts out & won’t restore.
Do you have to choose between live stream and recording? Or is there a way to do both?
I believe the link has expired. Would love to have this app to evaluate latencies.
You can simply measure latency by having the FPV camera looking on a clock (e.g. Computer Clock showing milliseconds) putting the Herelink side by side with that clock, take a photo and compare the time stamps.
def. I have done that. I’m trying to analyze how much latency is in each component. camera, tx, rx, and app.
Does the Herelink use HDCP? If So can it be disabled?
I am having very similar issues with a GoPro 5. One temporary fix is to reset the GoPro to Factory defaults, and then it sometimes works. Other times I need to power cycle the air unit. The best outcome usually occurs immediately after the Solex Tx app stops responding, and I close and reopen it. Then I get the streaming (no other changes). I have the latest Solex and the latest Herelink software/firmware as of last week. Something is clearly either wrong or not compatible here. Any thoughts?
I have issues with GoPro 7 Black - I can get video stream work sometimes but success rate is about 50/50. Solex is more problematic than QGC in that regard - which is strange - as issue should be more on airunit/GoPro side.
On another hand Mapir3 hdmi out works much more reliably.
I have a kind of this issue too. Solex is not stable sometimes it show streaming video and somtime waiting till time out, cannot streaming video. I tried to reset factory both herelink and air unit then it’s work perfectly only a few flight. After that the same issue coming back again. So, I surely that the issue is on sofware or firmware.
Can anyone tell me, GoPro Hero 9 is compatible or not with Herelink ?
Im think I might be able to use this to troubleshoot my setup Flir Vue Pro R → HDMi converter-> Herelink. Im familiar with how to install apps on the Herelink. Had to add the apk for Flir UAS qpp to configure camera. Just not sure if this is relevant to my situation or if this file is still available but i am curious.
