How to use an IP Camera over Herelink
Hi All,
In response to a question on another thread, here are some quick instructions for how to use an IP camera with a Herelink.
  • Set the IP address of the camera to be in the 192.168.144.0/24 range
  • Open the Application Settings in QGC on the Herelink
    – Scroll to the Video Setting section
    – Change video source to one compatible with your camera (RTSP, UDP H264, etc)
    – Enter the details for your camera (Keep file format and video decode priority at defaults)
  • Close settings
@fdfilmprod Forgot to tag you. Please see the post above.
I tried the steps you have done. I am using a norden ip camera . it has an ip in the range 192.168.144.0/24 and so does my pc, but when I try to connect to herelink I don’t see any results. Any help is appreciated.
