Installed 2 modules on can bus here 2.
In Mission planer, only 1 compass of 2 is visible. It is visible as # 3. Help me find the second compass! I want 2 compasses working simultaneously
The result works only 1 compass which is primary driver
This is solved in latest beta.
AC4.0.4beta
The issue is the current Ardupilot release sets all Internal and SPI compass ahead of CAN.
There is two solutions.
The first is toy run the current master build and you will find you can now adjust their positions.
The second is to use the Compss_Typemask command time disable the internal SPI compass and then the can will be default.
Also you need to set the drivers and 1 and 2.
