Metallic cube, 4.5/4.4 Config Error: Board Validation $CHECK_BARO1_PRESEN
We are using metallic cube, it was working but today is stopped and showing this error.
We were on 4.4.4 and got this error, now updated to latest still getting this error
27-06-2024 13:09:51 : T Failed
27-06-2024 13:09:51 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:09:50 : Config Error: fix problem then reboot
27-06-2024 13:09:46 : T Failed
27-06-2024 13:09:46 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:09:45 : Config Error: fix problem then reboot
27-06-2024 13:09:41 : T Failed
27-06-2024 13:09:41 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:09:40 : Config Error: fix problem then reboot
27-06-2024 13:09:36 : T Failed
27-06-2024 13:09:36 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:09:35 : Config Error: fix problem then reboot
27-06-2024 13:09:31 : T Failed
27-06-2024 13:09:31 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:09:30 : Config Error: fix problem then reboot
27-06-2024 13:09:26 : T Failed
27-06-2024 13:09:26 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:09:25 : Config Error: fix problem then reboot
27-06-2024 13:09:21 : T Failed
27-06-2024 13:09:21 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:09:20 : Config Error: fix problem then reboot
27-06-2024 13:09:16 : T Failed
27-06-2024 13:09:16 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:09:15 : Config Error: fix problem then reboot
27-06-2024 13:09:11 : T Failed
27-06-2024 13:09:11 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:09:10 : Config Error: fix problem then reboot
27-06-2024 13:09:06 : T Failed
27-06-2024 13:09:06 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:09:05 : Config Error: fix problem then reboot
27-06-2024 13:09:01 : T Failed
27-06-2024 13:09:01 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:09:00 : Config Error: fix problem then reboot
27-06-2024 13:08:56 : T Failed
27-06-2024 13:08:56 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:08:55 : Config Error: fix problem then reboot
27-06-2024 13:08:51 : T Failed
27-06-2024 13:08:51 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:08:50 : Config Error: fix problem then reboot
27-06-2024 13:08:46 : T Failed
27-06-2024 13:08:46 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:08:45 : Config Error: fix problem then reboot
27-06-2024 13:08:41 : T Failed
27-06-2024 13:08:41 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:08:40 : Config Error: fix problem then reboot
27-06-2024 13:08:36 : T Failed
27-06-2024 13:08:36 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:08:35 : Config Error: fix problem then reboot
27-06-2024 13:08:31 : T Failed
27-06-2024 13:08:31 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:08:30 : Config Error: fix problem then reboot
27-06-2024 13:08:26 : T Failed
27-06-2024 13:08:26 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:08:25 : Config Error: fix problem then reboot
27-06-2024 13:08:21 : T Failed
27-06-2024 13:08:21 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:08:20 : Config Error: fix problem then reboot
27-06-2024 13:08:16 : T Failed
27-06-2024 13:08:16 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:08:15 : Config Error: fix problem then reboot
27-06-2024 13:08:12 : motors not allocated
27-06-2024 13:08:12 : RCOut: Initialising
27-06-2024 13:08:12 : IOMCU: 420 1001 411FC231
27-06-2024 13:08:12 : CubeOrangePlus 00200026 30325114 33383839
27-06-2024 13:08:12 : ChibiOS: 6a85082c
27-06-2024 13:08:12 : ArduCopter V4.5.4 (fd1bcc61)
27-06-2024 13:08:11 : motors not allocated
27-06-2024 13:08:11 : RCOut: Initialising
27-06-2024 13:08:11 : IOMCU: 420 1001 411FC231
27-06-2024 13:08:11 : CubeOrangePlus 00200026 30325114 33383839
27-06-2024 13:08:11 : ChibiOS: 6a85082c
27-06-2024 13:08:11 : ArduCopter V4.5.4 (fd1bcc61)
27-06-2024 13:08:11 : T Failed
27-06-2024 13:08:11 : Config Error: Board Validation $CHECK_BARO1_PRESEN
27-06-2024 13:08:10 : Config Error: fix problem then reboot
@Mjg was the Cube opened by any chance or tampered with, If not please contact your reseller and ask for RMA.
No we are using Cube on the mini carrier board
@Mjg - did you ever find the root cause of this issue?
