Tested today the Workswell Wiris mini thermal camera - no video stream was displayed. Tested the Wiris with several HDMI monitors with success. What problem can be? Have the same issue with the Emlid Edge flight controller. I assume that it have something to do with gstreamer. Any ideas how I can solve the problem?
what is the resolution and frame rate of your camera output? if it is 1080p 60fps it should work straightaway. if not you might need to check and adjust the herelink frame rate in the controller setting
Where can I find these settings in herelink?
No hints?
Look at my second screen shot in this thread
