Possible to buy a new Here4 GPS Cable?
I had a crash and the cable on my Here4 GPS had a wire end up getting cut on it. Is it possible to buy just a new cable for the Here 4 GPS? The one that comes standard with it is all I think Ill need.
Do you mean this?
That’s close. Except the cable it came with only has one end that connects inside the GPS unit (I think it’s maybe a 10p jst connector internally, I’d have to check on that) and then it comes out to 2 4p jst CAN connectors.
The cable might not be buyable cause that should be part of the here4. I think fixing the wire back might be a better solution. Might make the here4 non-waterproof with the cable changed.
