Hello everybody,
I have an pixhawk orange cube as arducopter, and I wanted to activate Aux Out 5 as a relay.
I also set the parameters in Mission Planner:
BRD_PWM_COUNT = 4
AUX out was set to 54, relay 2
And when I go into the Flight Data menu and want to test the Relay 2 function, nothing happens, only with servo output No.13, there I get a voltage change when clicking, between 0.1 - 0.3 V
How does this relay output work? Is this an open / close contact? Or how should it work this relay output? Do you need an additional relay board?
Where exactly do you have to connect the contacts?
I want to turn a headlight on and off.
Don’t understand the logic behind it.
Thank you for!
