CubeOrange Arducopter 4.5.6
I measure the + (Red) and - (black) pins, 0.0V, and measure S (Signal) and - (black), 0.0V. Main out + pins (1-6) are currently open, and not connected to ESC.
Do I need to supply external power (5V/ 3.3V) to Main Out + pins? Something like that?
Is the servo rail in the article referencing Main Out + pins? What about AUX power referring to?
I am concerned about burning the CubeOrange (not a cheap board).
I am still confused about the entire Power Architecture.
# https://ardupilot.org/copter/docs/common-gpios.html#version-4-2-and-later
BRD_PWM_VOLT_SEL,0 # 3.3V
RC11_OPTION,28 # Relay1 On/Off
RELAY1_DEFAULT,0
RELAY1_FUNCTION,1 # Relay, save and refresh
RELAY1_PIN,107 # MainOut7
SERVO1_FUNCTION,33 # M1
SERVO2_FUNCTION,34 # M2
SERVO3_FUNCTION,35 # M3
SERVO4_FUNCTION,36 # M4
SERVO5_FUNCTION,37 # M5
SERVO6_FUNCTION,38 # M6
SERVO7_FUNCTION,-1 # setting a PWM/SERVO/MOTOR output to be a GPIO function
17/09/2024 13:24:51 : PreArm: RELAY1_PIN=107, set SERVO7_FUNCTION=-1
17/09/2024 13:24:20 : PreArm: RELAY1_PIN=107, set SERVO7_FUNCTION=-1
17/09/2024 13:23:58 : RC11: Relay1 LOW
17/09/2024 13:23:56 : RC11: Relay1 HIGH
17/09/2024 13:23:54 : RC11: Relay1 LOW
17/09/2024 13:23:50 : RC11: Relay1 HIGH
17/09/2024 13:23:49 : PreArm: RELAY1_PIN=107, set SERVO7_FUNCTION=-1
17/09/2024 13:23:46 : RC11: Relay1 LOW
17/09/2024 13:23:40 : RC11: Relay1 HIGH
17/09/2024 13:23:18 : PreArm: RELAY1_PIN=107, set SERVO7_FUNCTION=-1
17/09/2024 13:22:47 : PreArm: RELAY1_PIN=107, set SERVO7_FUNCTION=-1
17/09/2024 13:22:25 : RC11: Relay1 LOW
17/09/2024 13:22:25 : RC10: MotorEStop LOW
17/09/2024 13:22:25 : RCOut: PWM:1-14
17/09/2024 13:15:41 : CubeOrange 00420019 3239510C 38363839
17/09/2024 13:15:41 : ChibiOS: 6a85082c
17/09/2024 13:15:41 : ArduCopter V4.5.6 (7ce11b41)
