I was holding on to hopes and prayers that my distributor had old stock that is not of concern here.
…but i think i am out of luck. looks like my cube sourced from a distributor is post-Jan19. Due to “CUBE” marking on top and clips instead of screws holding the lid down.
My cube setup has not shown the SB warning in MP, HW IDs match, BRD_TYPE is correct, no “init Cube Black” errors and no INS errors. Which is awesome! But that is all on the bench. Knowing what we know about this fault, is it possible the symptoms will show after some time? maybe simply powered on time with current flowing? or after a few flights?
Hello guys, I’m a new cube user and I may be affected on this bulletin. (bouth on 02/13/19 from ir-lock)
I’ve followed every instruction that was told to follow and read all comments in this page, i’m using newest beta version mission planner, arducopter 3.6.8 hexa, changed the board parameters and MP didnt warn about the service bulletin until now.
I know that is massive, but I can fly safely ?
FYI I’ve never flew with this board I just turned it on a few times, its a brand new board and i’m still running heating and cooling cicles, as philip said, and until know, MP dont warned about the service bulletin.
But in this firmware we have to upload the cube black code by our own which I tried as stated above and after rebooting only once I was able to arm the copter and then after same error is shown in mission planner. I am asking you to give us a fresh firmware in which all parameter are set by default by computer itself. Because uploading the code manually is so confusing. Despite following instructions listed above I was only once able to arm the copter. If you will release the parameter in a firmware form we have to not do it manually. I uploaded the previous firmware and able to fly but I will not fly in future with previous firmware I was jus testing it. Many users above also listed the same issue that despite uploading cube black code they are getting error
Despite of using latest mission planner and uploading latest firmware on the board and after uploading cube black code I am receiving the same error Check_BRD_TYPE FAILED TO INIT CUBE BLACK SENSOR.I think my hardware is faulty,so what to do now or what are you doing to solve this.
