I have multiple systems using the HERE+ RTK. We sometimes have height issues, but thought this was in our system. But apparently it is not. The latest flight again showed one drone being 4 meter lower than the others.
Two drones starting at same height and landing at same height. But graphs show another story? This is GPS_RAW_INT I’m plotting
I just checked and the version on the base station is:
HPG 1.30 REF
The version on the drone is:
HPG 1.40 ROVER
I.e. the rover has already “a quite recent version”. Not sure if it would make a difference to update?
That is true. I found out that this corresponds to the moments the RTK solution is FIXED. Which means that the resolution is better. Not sure I understand why when going back to a FLOAT solution makes it immediately that bad …
